davet
Standalone application does not run without JTAG connected
I have a standalone application developed with Vitis 2020.1 on a Zynq 7000 that runs as expected with the debugger. However, if I create a bootimage and program it into flash (QSPI boot), the application only runs IF a JTAG programmer is plugged in (I've tried both Platform Cable and SmartLynq).
I am using the auto generated FSBL that gets created with the Platform project in Vitis. The FSBL appears to work and does program the PL -- it just looks like the application doesn't start, like it may be in reset or have a stopped clock. However, as soon as I plug in the JTAG cable, the application starts running. I can remove the JTAG cable and it continues running. I've done some probing and saw there is activity on the JTAG lines without taking any action in Vitis, and I want to believe that the presence of the JTAG clock (or maybe other signals) is having an impact. None of the other signals from the Xilinx programmers are connected -- just vref and tms/tck/tdo/tdi.
Has anyone experienced this before or have any ideas? I'm starting to go down the path of digging into ps7_init.c, since that's one part of the boot process that least familiar with / most suspecting of.
denist
Do you have a UART? I saw this if the stdout in the BSP for the FSBL is set to "coresight" instead if UART or NONE.
denist
Steves_Job
Did you find the the problem? I am having the same issue. Changing the stdout to none did not change the behavior.
davet
Changing stdout and stdin to UART/NONE did resolve this for me.
jhouee
Hello
I have the same issue but I didn't selected any UART in my design.
Where do you change  stdout and stdin to UART/NONE ?
Johann
boychantrau_9a4
@jhouee  you can right click your fsbl_bsp -> board support package settings -> standalone -> there you can see stdout setting, change it to uart/none
