TrustZone violation on PL-PS interfaces ?
Hi, as far I understood the TrustZone configuration for the PL-PS interface is defined on a per transaction basis. Let us now consider a unsecure Master in the PL which modifies the AWPROT[1]/ARPROT[1] signals to generate a secure memory transaction through one of the FPD interfaces. What are the current possibilities  to prevent this privilege escalation ? For me one solution would be to define the isolation correctly with the Isolation Configuration flow. Is it also possible to prevent this at the FPD interface itself ?
Best regards,
Mathieu
Firts of all I suggest to authenticate the PL bitstream so you are only loading "authorized cores".
Now if your core has a bug with those signals, some Isolation in the PS could definetly help since the transaction can be blocked or allowed depending on the MASTER ID.
