robster
U-boot: enable dfu device on zc702
Hej,
I'm tying to enable U-boot on a ZC702 evk board to act as a DFU device. I'm building/deploying the latest u-boot-xlnx-v2018.2 github release (I've added a couple of extra printf, but that's it) .
Trying to enable dfu looks like this in the prompt:
Zynq> run dfu_mmc_info
Zynq> run dfu_mmc
run_usb_dnl_gadget usb_dnl_dfu
board_usb_init index:0 type:1
usb_setup_ehci_gadget: uclass_find_device_by_seq return:-19
g_dnl_register: failed!, error: -19
ENODEV (No such device) is returned.
I've tried to change the default dr_mode for the USB device in the device-tree from 'host' (which doesn't seem right for this implementation) to 'otg' and 'peripheral' (including changing jumpers on the evk board) generate the same result (the later renders no usb function at all).
Well I guess I could simplify the problem description to: unable to enable any gadget functionality on zc702-evk board.
Is there any other initialization I need to do before starting the dfu device?
Any pointers/suggestions on what to do I greatly appreciated.
Hälsningar
Robert
aravindb
HI Robster,
Add the following lines in the system-user.dtsi
/include/ "system-conf.dtsi"
aliases
{ usb0 = &usb0; };
&usb0
{ dr_mode = "peripheral"; };
  1. Boot the board in SD boot mode and stop at the u-boot prompt
  2. On u-boot prompt run the following command
    run dfu_ram
  3. On Host machine run the following command:
    dfu-util -l
    After running this command, you can see the device like this:
dfu-util 0.8
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2014 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to dfu-util@lists.gnumonks.org
Found DFU: [03fd:0300] ver=0221, devnum=9, cfg=1, intf=0, alt=0, name="image.ub", serial="UNKNOWN"
  1. On host machine, run the following command
    dfu-util -d 03fd:0300 -D images/linux/image.ub -a 0
  2. Once it download the image.ub, on u-boot prompt
    Ctrl+C
  3. bootm
Note: Make sure this driver has to be installed in host machine( if it is windows):
https://downloads.tomsguide.com/Zadig,0301-65957.html
This i already verified and it is working fine.
aravindb
HI,
Please follow below steps USB device mode test
1. Download till u-boot and stop at the u-boot prompt.
2.Connect board to host PC using USB0 and install dfu util on host PC.
3. Download the windows download utility(dfu-0.7) from http://dfu-util.gnumonks.org/releases/
4.At the u-boot prompt enter command "run dfu_ram" to enter into the Device mode.
5.At the Host side the device should be detected.
6.Then go to the command prompt and cd to dfu-util folder and try to run dfu-util.exe from command line with options as below.
 a. dfu-util.exe -l
 b. the zynq device should be listes as DFU capable.
 c. Then download uImage from host using command "dfu-util.exe -a 0 -D Image
 d. Download the fdt to device using the same command but "-a 1"(for fdt) ("dfu-util.exe -a 1 -D system.dtb).
 7.Run the u-boot boot command, booti (booti $kernel_addr - $fdt_addr) to boot kernel.
Log:
ZynqMP> run dfu_ram
To enable the  dfu support  please enable the below config options:
petalinux-config -c u-boot
CMD_DFU=y
DFU_PRAM=y
Need to pass dr_mode=peripheral  in device tree.
I verified in zynqMP platfrom, and not verified in zynq  but i hope this info will help you.
you can refer this link for more info: https://www.xilinx.com/support/answers/69378.html
Thanks & regards
Aravind
robster
Hej Aravind,
Sorry for not getting back earlier...vacation times n' all that.
The problem isn't enabling DFU functionality, it's what comes after....enabling USB to act as a device/gadget.
I've changed dr_mode=peripheral  in device tree....sill no dice.
Can u-boot be configured in any way to enable (any) USB gadget functionality on a zynq platform?
USB device model doesn't seem to support USB gadget framework( see usb-info.txt), is there a workaround for this?
Hälsningar
Robert
aravindb
HI Robster,
aliases
{ usb0 = &usb0; };
&usb0
    run dfu_ram
    dfu-util -l
dfu-util 0.8
    Ctrl+C
  3. bootm
robster
Thanks Aravind.
It works like a charm.
Hälsningar
Robert
