05-21-2019 06:09 PM
Hi all, I recently started developing on a ZCU102 board, and was able to program the FPGA just fine through the Xilinx SDK GUI (2018.3). However, today the INIT_B light has been stuck on red, even after power cycling multiple times. I was working on reading and writing data to the FPGA when I first noticed this.
This is a known issue for me, but for a while, I have not been able to program the FPGA through the SDK GUI, I get an error saying
Program FPGA failed bitstream is not compatible with the target revision, use -no-revision-check to allow programming
Since I've known about this issue so I'm not concerned about it (unless it's relevant to the later problem).
So then I run the XSCT command:
xsct% fpga -no-revision-check C:/.../bitstream.bit
And I get the following:
initializing xsct% fpga initialization failed
I've never seen this error before.
When I open Vivado, I get a warning from Auto Connect saying
[Labtools 27-3421] xczu9_0 PL Power Status OFF, cannot connect PL TAP. Check POR_B signal.
Both lights remain on throughout the process, and even after power cycles. Sometimes the PS_ERR_OUT light turns off after I run a debug instance. I would like to try wiping the flash, but I don't have a tool that will do that, and I'm not familiar with Vivado enough to know what I am doing.
Any ideas on what I can do?
05-22-2019 12:19 PM
Make sure you are using working image. If the mode pins are set to other than JTAG then try to set them to JTAG mode and load the design bit file and see if those LEDs goes off.
If it does then use the same bit file to create flash file and then share the results. Since this is our evaluation board, so you can use prebuilt images which can be found here https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0048-zcu102-evaluation-kit-hub.html
From the revision check message it apprears that you are using ES2 board which is why tool is complaing about the rev mismatch.
For erasing the flash you can follow the AR https://www.xilinx.com/support/answers/72140.html
In Vivado/SDK, you will find this option in flash programming GUI.
Hope it helps.
Harshit
05-22-2019 03:32 PM
05-22-2019 03:44 PM
