ADMU_1312
Unable to do JTAG flashing in Xilinx ultrascale+ MPSOC(XCZU3EG). The error is "Problem in running uboot"
We are trying to to do JTAG flash but we receive the following error.
Flash operation failed.
Please find the complete log below:
We also took the UART log while doing the flash process. Pasting it below:
Please let us know how to resolve this issue.
abommera
Hi @ADMU_1312 ,
By looking into your flash programming log, the current boot mode is QSPI. Please try with JTAG boot mode while QSPI flash programming.
Thanks & Regards
Anil B
abommera
Hi @ADMU_1312 ,
Thanks & Regards
Anil B
ADMU_1312
I configured my board into JTAG boot mode by shorting the required pins. But still the Flash happens in QSPI boot mode. Do I need to do something else apart from required hardware setup?
abommera
Hi @ADMU_1312 ,
You can change boot mode to JTAG in fsbl application and try. Please refer to AR# 70548 for your reference.
Thanks & Regards
Anil B
