deville
Xilinx ZynqUS: Can U-boot do a boot through to another boot.bin ? ( Or other suggestions?)
Hi Xilinx
I want to boot from QSPI, load a basic configuration (PL and Basic U-boot device tree) and then stop at the Uboot command line.
There I like to have a choice with multiple boot options.  For instance: Boot from Emmc with the full blown version of out FPGA code or do a tftp update, etc...
My question(s):
Is this possible and how can you make the reboot from within U-boot?
If no: What is the best way to approach this problem?
Thanks in advance.
Note: The Emmc also meant to have a Uboot in it's schematics, but you get the idea.
stephenm
stephenm
deville
Ok Thanks for this, I'll have a look into the docs
deville
Hi @stephenm
As an addendum to this post;  Is it possible to restart or reboot the Zynqmp, even with the PMU already running?
This would make my original question a valiable path to explore: Startup from QSPI and in a later stage boot through to the emmc or the SD card for example.
