Visitor zfandlu
Z7030 can't boot from QSPI
Hi:
   I want my board boots frome QSPI, but it can't work. I am sure the boot file *.bin has been downloaded into Flash, and the FSBL code should work. this is the debug information after boot from QSPI mode:
Xilinx First Stage Boot Loader
Release 2014.4 May 5 2016-22:17:06
Devcfg driver initialized
Silicon Version 3.1
Boot mode is QSPI
Single Flash Information
FlashID=0x1 0x2 0x19
SPANSION 256M Bits
QSPI is in single flash connection
QSPI Init Done
Flash Base Address: 0xFC000000
Reboot status register: 0x60400000
Multiboot Register: 0x0000C000
Image Start Address: 0x00000000
Partition Header Offset:0x00000C80
Partition Count: 3
Partition Number: 1
Header Dump
Image Word Len: 0x0016CFC8
Data Word Len: 0x0016CFC8
Partition Word Len:0x0016CFC8
Load Addr: 0x00000000
Exec Addr: 0x00000000
Partition Start: 0x000055D0
Partition Attr: 0x00000020
Partition Checksum Offset: 0x00000000
Section Count: 0x00000001
Checksum: 0xFFBB3866
Bitstream
In FsblHookBeforeBitstreamDload function
PCAP:StatusReg = 0x40000A30
PCAP:device ready
PCAP:Clear done
Level Shifter Value = 0xA
Devcfg Status register = 0x40000A30
PCAP:Fabric is Initialized done
PCAP register dump:
PCAP CTRL 0xF8007000: 0x4C00E07F
PCAP LOCK 0xF8007004: 0x0000001A
PCAP CONFIG 0xF8007008: 0x00000508
PCAP ISR 0xF800700C: 0x0802000B
PCAP IMR 0xF8007010: 0xFFFFFFFF
PCAP STATUS 0xF8007014: 0x00008A30
PCAP DMA SRC ADDR 0xF8007018: 0x00100001
PCAP DMA DEST ADDR 0xF800701C: 0xFFFFFFFF
PCAP DMA SRC LEN 0xF8007020: 0x0016CFC8
PCAP DMA DEST LEN 0xF8007024: 0x0016CFC8
PCAP ROM SHADOW CTRL 0xF8007028: 0xFFFFFFFF
PCAP MBOOT 0xF800702C: 0x0000C000
PCAP SW ID 0xF8007030: 0x00000000
PCAP UNLOCK 0xF8007034: 0x757BDF0D
PCAP MCTRL 0xF8007080: 0x30800100
DMA Done !
...................................................................................................PCAP transfer timed out
PCAP_FPGA_DONE_FAIL
PCAP Bitstream Download Failed
PARTITION_MOVE_FAIL
FSBL Status = 0xA00B ? Xilinx First Stage Boot Loader
Silicon Version 3.1
Boot mode is QSPI
SPANSION 256M Bits
QSPI Init Done
Reboot status register: 0xF0480000
Multiboot Register: 0x0000C200
Image Start Address: 0x01000000
Bank Selection 1
Bank Selection 1
Partition Header Offset:0x00FFFFFF
Bank Selection 1
Partition Count: 14
Invalid Partition Count
Partition Header Load Failed
FSBL Status = 0xA00E
It seems some trouble with PCAP,but this is little information.
Visitor fourrunner72
Re: Z7030 can't boot from QSPI
Hi, I have a similar issue.  Did you ever wind up fixing it? Was it a HW issue?
Jeff
Hi, I have a similar issue. Some times, the board(7z020) can boot, but some times it can't. Did you fixed it and how.
Does this issue related to DDR or HW?
Have you fixed it?
Jeff
Your BootRom error code of 0xA00E indicates an FSBL SPK failure (bit 15), and address in the BootROM header is outside of the addressable range (0x200E).
Did you intend to have RSA enabled? If not, make certain your power-on and power-off timing meets that in AR65240
Ok, I will check my power on and power off timing.
