Observer shyamthella
ZC702 Uboot changes to load image.ub from SPI flash
Hi All,
I am able to flash BOOT.BIN to ZC702 spi flash using sf commands. But when I power cycle the board and try to boot it, its hanging at uboot command prompt. I believe U-boot needs some command defined to load image.ub from spi flash to RAM and execute kernel.
Can you tell me SPI address to load image.ub?
Also where should I load image.ub from flash using sf read to RAM? RAM location to read image.ub from spi flash.
Shyam
Re: ZC702 Uboot changes to load image.ub from SPI flash
If you use petalinux to generate the image, please find platform-auto.h from your project.
Then kernelstart shows the flash offset and netstart shows the load address of memory.
Thank you.
Can we load an extracted rootfs contents to spi flash?
I know how to use compressed rootfs fromflash using an itb file.
Xilinx tends to use .ub extension (i.e. Yocto generates the fitimage.itb or fit.itb file in deploy/images/<machine_name> directory and PetaLinux tools will rename this to image.ub while copying to <plnx-proj-root>/images/linux directory.)
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842374/U-Boot+Images
Thats Okay. Iam now able to flash BOOT.BIN and my .itb file to SPI and boot it properly. I want to make changes that are made to my rootfs to be persistent over multiple boots. For this a compressed image will not help right. So I want to use extracted rootfs which is copied to SPI flash.
Will this is possible on ZC702?
Shyam
you can boot Linux with individual Kernel image, rootfs , device tree file.
See P.45
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug873-zynq-ctt.pdf
Thanks for pointing it. But the command there says "dow -data uramdisk.image.gz 0x2000000" which is to copy a compressed ramdisk image to SPI flash. I told I want to use uncompressed ramdisk folder to be used as my file system. Is there a way to achieve this?
Shyam
