ZC706 boot from SD card
I would like to test the read_to_test image based XAPP 1082 on :
https://www.xilinx.com/support/documentation/application_notes/xapp1082-zynq-eth.pdf
Under the read_to_test folder, there are two files: BOOT.BIN and image.ub, which I need put it on SD card
of ZC706 board, so I have two questions:
1. I just put this two files to SD card? Which folder? Or I need create .gz file?
2. Can I use 1.0GB SandDisk for ZC706 board?
Re: ZC706 boot from SD card
Both BOOT.BIN and image.ub are needed.
1.0GB SandDisk is OK.
Thanks for reply, I copy these two files in SD card and put it on ZC706 board, nothing print out from hyperterminal, should I re-format
the SD card and only put these two files?
Please check the boot mode pin settings. For your reference attached the screenshot.
Refer this links for more details :http://www.wiki.xilinx.com/Prepare+Boot+Medium
https://www.xilinx.com/support/documentation/boards_and_kits/zc706/2015_4/ug961-zc706-GSG.pdf
Thanks & regards
Aravind
Yes, I have right setting, I did sd card partition, put boot.bin and image.ub on fat sector, rootfs.cpio on second sector, the system booted up, but not working as expected, just wondering rootfs.cpio is necessary for 2017.4?
thanks
Hi ,
No need to copy rootfs.cpio in 2nd partition. BOOT.BIN & Image.ub is enough to boot the board, Image.ub is combination of  kernel+DTB+initramfs.
what do you mean when you say "the system booted up, but not working as expected" . cloud you please let me know what you are expecting.
Thanks & regards
Aravind
