aroytman
ZCU102 PL programming
 Hello all,
I have some general beginner's questions on PL loading.
I need to do this for a proprietary RTOS.
Will appreciate pointers to relevant material or short, high level guidelines:
1. Is the CSUDMA the only way to load bitstream to PL (i.e. via PCAP) or there are alternatives?
2. Is Petalinux using this interface or something else can be used as well?
3. Is u-boot using this interface or something else can be used as well?
4. If there is another way, besides the one described in ug1085 - where can I find the documentation on that?
Thank you very much
denist
CSUDMA is the only way for the processors in the PS to program the bitstream.
Take a look at XilFpga library.
\SDK\2017.4\data\embeddedsw\lib\sw_services\xilfpga_v3_0\doc
denist
