m.h.leason
ZCU102 Slow Bitstream loading
I am using ZCU102 Board (Revision 1.1), It takes ~3s, from SD Card, and ~2s, from QSPI Flash, to load bitstream by FSBL, What is the problem?
P.S: I tested my design's BOOT.bin and also XAPP1305 Pre-Build BOOT.bin file.
ddn
Hi @m.h.leason ,
Please refer this AR#67475  which help syou to calculate boot time estimate from sdcard and flash.
Hope this helps.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
m.h.leason
Hi @ddn
Thanks for your reply
Accrording to AR#67475, booting from SD Card must take ~700ms to load bitstream, but my measurements shows ~3s, Why this difference exist?
glena
What is the frequency of your SD and QSPI implementations?  Is your QSPI single or dual-parallel?  Also, what is in your bif?  With your load times it doens't look like you are programming the PL.
