msh
Voyager
Voyager
ZCU106: QSPI mode doesnt work
I receive new hardware, where I did the initial test by booting it up in QSPI (mode set by switch) . This worked fine.
Then I made my own .mcs file by adding
This way I add the bootloader
This way I create the bootloader
After flashing the .mcs (QSDI mode according to switched ON OFF ON ON)file the program does not work i.e. the fpga is not able to initiate
The same software if I flash without bootloader in jatag mode (pins configured) i.e first flash fpga file (.bit) and then flash PS software (.elf) then it works fine. Therefore I think there is a problem in bootloader file
Please let me know if I miss some step for making bootloader file for board ZCU106.
Thank you
Best regards
msh
Voyager
Voyager
process :
1. check jumper for pcie to enable
2. make loop pcie PL implementation with xdma pcie IP
3. flash it into the flash memory with "qspi_dual_parallel" option or make boot image (fsbl + elf) and place in sd card
4. run xilinx driver for pcie in ubuntu 14.0
https://www.xilinx.com/support/answers/65444.html
project (.tcl) and boot image in the attachment
note : there is user ip to control LED (single_endto_diff_0), hence if that user IP is not loaded in the project no need to worrie :)
how to place pcie:
1. include xdma pcie
2. run auto setup
(select maximum width, stream, 1 connection )
3. then connect out stream to in stream (loop back)
4. change the pins for pcie in IO planner (as it is not corectly done automatically)
5. assign the input pcie clock in clock planner to 100Mhz.
6. make .bit file
7. export to sdk
8. make fsbl
9. make boot image
10. correct jumper setting in the board
11. conent the board to pcie slot in pc with ubuntu 14.0
12. check in the linux (lspci -v), as xilinx pcie
13. run the xilinx driver
All the best
smarell
Community Manager
Community Manager
Do you see any prints on serial terminal after you try to boot?
I would recommend you to follow the steps in https://www.xilinx.com/support/answers/68656.html to narrow down the issue.
msh
Voyager
Voyager
here is what I see in
Xilinx Zynq MP First StagýXilinx Zynq MP First Stage Boot Loader
Release 2018.1 þXilinx Zynq MP First SüXilinx Zynq MP First Sü
I even tried simple hello world but that also does not work.
Please see the flash log in the attachment.
I have this problem with both hardware (2 ZCu106)
msh
Voyager
Voyager
When I flash the file from the restore flash tutorial, then it works fine. but still, multiple restarts require to get to green lights.
So I do not understand where is the problem.
msh
Voyager
Voyager
Ther is another msg states PMU is disabled hence some function won't work properly?
Will that created problem?
msh
Voyager
Voyager
I ran the bootloader in debug mode, there I found this error
XFsbl_SpkVer: XFSBL_ERROR_SPK_SIGNATURE
Failure at boot header authentication
It seems there is a problem in FSBL generated from SDK for zynq ultrascale+ board ZCU106.
Please advice how to resolve it.
thank you
msh
Voyager
Voyager
here is the full log
denist
I also see this error in your log "XFSBL_ERROR_IHT_CHECKSUM".
It appears the image is corrupted in the "image header table".
msh
Voyager
Voyager
Here is the testing detail
This is my model (with PCIe), in serial output, it just prints "HelloWorld" (PS side) and runs PCIe connection on PL
1.
a. QSPI flashing test: FAIL
b. SD card run test: PASS
Please see the log and .bif in the attachment.
2.
I am not using DDR, hence other tests are not applicable.
3.
Normal QSPI hello world test:  PASS
Please see the log
Looking forward to suggestion.
tom0501
Hi! Now I work on ZCU106,and I add a DMA/Subsystem for pci express IPCore at PL. But wen I boot form SD card,kernel stop at [ 0.015866] bootconsole [cdns0] disabled.
As you say,your model also have pcie,and work well in SD card mode.Can you gave me a example design with PCIE?I hope it can help me to find out where is wrong,thanks!
msh
Voyager
Voyager
process :
how to place pcie:
2. run auto setup
6. make .bit file
7. export to sdk
8. make fsbl
9. make boot image
All the best
msh
Voyager
Voyager
tcl
tom0501
When I source the tcl file,I get error:
ERROR: [Vivado 12-172] File or Directory 'C:/Users/TOM/AppData/Roaming/Xilinx/Vivado/PCIeLoop.srcs/sources_1/bd/design_1/hdl/design_1_wrapper.vhd' does not exist
Can you tar the whole project?Thanks!
msh
Voyager
Voyager
sorry , the site is not allowing me to upload as it is too big for it.
try following the steps which I mention before
let me know if boot.bin file which I shared it works for you
joe306
Were you able to get things working. I am having the same problem. I am running a Peripheral example to toggle the LEDS. It completes programming the QSPI but when I power down and boot with the QSP boot mode setting it fails to init and get the RED led.
Any advice?
Thank you
Joe
