Zynq-7000 - Initialize BRAM from FSBL.
In this post @ryserp mentioned that a Zynq can execute code from BRAM.
Does this indicate that the BRAM can be used in place of DDR by the FSBL to hold the application?
If so, could someone provide some pointers on how to do that?
Re: Zynq-7000 FSBL load and execute application from BRAM.
Did some testing where an application was set to only use BRAM. Surprise surprise, it didn't work out.
I found the following in image_mover.c:
if ((PSPartitionFlag == 1) && (PartitionLoadAddr < DDR_START_ADDR)) {
	if ((PartitionLoadAddr == 0) &&
			(!((SignedPartitionFlag == 1) ||
					(EncryptedPartitionFlag == 1)))) {
		break;
	} else {
		fsbl_printf(DEBUG_GENERAL,
				"INVALID_LOAD_ADDRESS_FAIL\r\n");
		OutputStatus(INVALID_LOAD_ADDRESS_FAIL);
		FsblFallback();
if (PSPartitionFlag && (PartitionLoadAddr > DDR_END_ADDR)) {
	FsblFallback();
Obviously this stops the FSBL from writing an application to anywhere else than DDR.
I tried commenting that out, which resulted in the FSBL stalling before returning the status 0xA00B = Partition Move Fail. No surprise there.
Now I'm wondering: Can I initialize the BRAM from the FSBL? That should lead me somewhat closer to running my apps off BRAM.
If you want to initialize BRAM in the FSBL it has to be after the PL is configured.   Look at this WIKI, maybe it'll help you out.
Exactly. I see that the FSBL has some hooks, including
u32 FsblHookAfterBitstreamDload(void)
which I thought I could use for BRAM initalization.
I was wondering though, is it necessary to do any initialization of BRAM at all? I've used BRAM before and can't remember having to do much initialization.
Re: Zynq-7000 - Initialize BRAM from FSBL.
What are you trying to put in BRAM?   Typically the FSBL is used to load the elf into BRAM.
I'm looking into a few different solutions for a DDR-less design using both ARM Cores and the PL of the Zynq-7000.
In this case, I am trying to load the PS application.elfs into the BRAM and executing from the BRAM.
That would be done by an elf from the FSBL
How?
In my second post of this thread I show the code where the default FSBL does not allow a PS Partition to be written anywhere else than to DDR.
Also in the second post I tried removing the DDR region guard which causes FSBL partition move to time out.
this is done in the bif  it would contain the FSBL, bitstream, then the elf.   Your elf would be linked to the BRAM
//arch = zynq; split = false; format = BIN
the_ROM_image:
[bootloader]fsbl.elf
base_zynq_wrapper.bit
bram_code.elf
Be sure the PL is accessible from the PS when FSBL is loading the .elf.
In past releases we saw this https://www.xilinx.com/support/answers/55488.html
I am not sure if it's still applicable.
