dracoxue_946
Zynq-7000 SRST and POR (PS_SRST_B and PS_POR_B) Signals release Sequencing on power on
Hi, dear Xilinx's experts,
     I have a question about Zynq-7000 SRST and POR Signals release Sequencing on power on when I designning  a project.
     My project use XC7Z045 series chip. When I was reading UG585, I'm a little confused. Accoding to page 164 figure 6-4,
 PS_SRST_B is de-asserted before PS_POR_B being de-asserted(Pulling High).  But according to page 711,Figure 26-3:2.JPG
It is seems like PS_SRST_B is de-asserted after PS_POR_B being de-asserted for a ram memory clear.
So the what is the suggestted sequence  I should follow?
Thank you for your advance!
allanherriman
Mentor
Mentor
You can tie PS_SRST_B permanently high and it will work fine.
Typically SRST is just used for debugging.  For example, on my boards I tie it to a pullup resistor and the JTAG header and ESD protection and nothing else.
I use PS_POR_B to reset the board.  This is derived from the power supply supervisor(s).  This does not need to connect to SRST.
dracoxue_946
Hi ,thank you so  much for your  answer and detailed explaination!  On my board I also tie SRST to a pullup resistor. I want to ask you more about this question if you don't mind.
On my board, the voltage of bank PS 500 where PS_POR_B  locates in is 3.3V,  the he voltage of bank PS 501 where PS_SRST_B  locates in is 2.5V.
During different power supply squencing  power on, should 2.5V power on before 3.3V or after or it doesn;t matter?
Thanks for your help
dracoxue_946
jhouee
Could you tell me why the PS_POR_B asserted doesn't erase the PL bitstream  if I have PS_SRST_B floating or pulled up  ?
In fact only PS_SRST_B asserted reset my bitstream whatever PS_POR_B status.
Br
Johann
