Zynq 7000 Standalone OS boot from SD card on zturn board not working
I'm able to program the FPGA and load the C hello world app using JTAG.  I get the uart output on my PC.  When I load to SD it does not work.  I create boot image with a FSBL.elf as the bootloader, the hardware design.bit, and the hello world .elf.
Turning the power off and then turning back on fixed this issue.  Also making a standalone OS bsp for the fsbl as mentioned in this guide worked:
http://svenand.blogdrives.com/archive/201.html#.XfulCldKguV
