Observer keil
Zynq-7020 SOC - Cannot find CPU1
Hi,my board is zynq7020.I build a project with cpu0 and cpu1,but When trying to debug the two cores in sdk, I got the error like this:
I can only see cpu0 and fpga,and cannot find cpu1.
I have tried to connect ARM in XMD,it also connot find cpu1.Then,I read register slcr.A9_CPU_RST_CTRL,the value show CPU1 is not under reset.
What can cause this issue?
Re: Zynq-7020 SOC - Cannot find CPU1
Hi @keil ,
Can you try targets command in xsct/xmd console before trying to run any application on device?
Power cycle the device and then try targets commands in console if you haven't done this already.
Thanks & Regards
Anil B
