Zynq MPSoC eMMC boot partition support
I have a question regarding booting a Zynq MPsoC System from an eMMC device.
Beside the (big) user partition eMMC devices are equipped with two additional boot partitions.
This feature would allow to implement a safe and an atomic update of the actual boot partition content.
The boot partitions can only be used when the host system uses one of the two eMMC boot options
'e-MMC ver. 4.3 Boot Option 1' and 'e-MMC ver. 4.3 Boot Option 2'. A brief summary of them can be found in the Micron's technical note ' Booting from Embedded MMC' [1].
Otherwise the host system will always just boot from the user partition and there is no bullet proof way to update the boot partition content.
For example a power cut while writing the new boot.bin in the boot partition most likely will corrupt the partition. Since the FAT file system is not a journaling system even just an interrupted file rename operation may corrupt the partition.
So, does the internal ROM code of the CSU/PMU support booting from eMMC boot partitions?
 ~Matthias
[1] https://www.micron.com/~/media/documents/products/technical-note/nand-flash/tn2918.pdf
Re: Zynq MPSoC eMMC boot partition support
No.
No.
