cntoinecreaform
Zynq Z7-20 not booting from sd card.
Vivado/Vitis 2019.2
I know this is a popular question, but I have tried everything I found and still can't get it to work.
I have tried 2 different 8Gb microSD card Formated in FAT32. I even booted Linux and followed the instructions here : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841655/Prepare+Boot+Medium
My design is fairly simple :
Capture_zynqDesing.PNGAll I do in my application is I turn one of the two RGB leds on my Arty Z7 to red :
#include "xparameters.h" /* SDK generated parameters */
#include "xgpio.h"
#include "xplatform_info.h"
XGpio rgbInst;
int main(void){
	int Status;
	XGpio_Initialize(&rgbInst, XPAR_GPIO_0_DEVICE_ID);
	XGpio_SetDataDirection(&rgbInst, 1, 0x00);
	XGpio_DiscreteWrite(&rgbInst, 1, 0x04);
	return XST_SUCCESS;
The code runs fine when launched from Vitis.
I created a BSP for the FSBL that includes xilffs & xilrsa
and an application project based on this bsp with the fsbl template.
Then I create the Boot Image :
and I drop the Boot.bin at the root of the sd card as the only file on the card.
The jumper on my devkit is placed properly on the SD card position, but the card won't boot. Nothing happens. The Done Led dosen't turn on.
Is there something I am missing here?
Thank you.
katsuki
Hello @cntoinecreaform
Is your SD card 8Gbit or 8GByte?
If you format the entire area of the SD card with FAT32, enable FSBL Debug Print and look at the log, you may find something.
If you think there is something wrong with your board, you can ask Digilent.
Thank you
Ka2ki
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
cntoinecreaform
@katsuki  I followed your advice and found that the FSBL is failing at the DDR verification. Since I don't really need the DDR in my desing, I found this document on how to use the fsbl without DDR : https://www.xilinx.com/support/answers/56044.html
but it is outdated. Is there an updated documentation on how to do this with Vitis?
Thank you!
