01-03-2019 07:18 AM
I'm implementing a system where I want to perform remote upgrades. I imagine years from now wanting to push a boot image with new keys. How would I go about doing this?
If I have something like the following partition table:
0: Primary boot
1: Primary boot update
2: Fallback boot
3: Fallback boot update
So the system receives new boot images (primary and fallback updates) to be written to 1 and 3. How can these be encrypted with new keys?
Thanks a lot for any guidance!
01-17-2019 08:42 AM
Suggestion:
If you don't force the encryption programming the eFUSE you can boot securely or non-securely depending on the boot header.
Let's say you have a working encrypted image first and a non-secure image for fallback.
In this case the update should look like this:
1- Erase the boot header of the secure image first.
2- Erase the whole secure image
3- Update the key
4- Write the new secure image except the boot header
5- Write the boot header of the new secure image
6- Issue a POR_B
If anything goes wrong you should be able to temporary boot into the non-secure fallback image.
the boot header is the key to avoid try to boot securely and fallback non securely. Does that make sense?
01-07-2019 01:48 AM
01-08-2019 10:24 AM
You need two separate .bif. One for your primary image and the other one for fallback.
The boot header will tell the key source to the ROM.
NOTE: If the device try to boot using the key from eFUSE, it cannot fallback to an image with key in BBRAM.
You need a POR in between, so this method only work if the device doesn't see the primary image at all (the boot header is corrupt).
I don't think this is the right way to fallback.
01-10-2019 07:32 AM
01-11-2019 09:25 AM
Your understanding is correct. If the ROM try to boot with an image encrypted, the possible fallback needs to have the same key source.
If not the ROM won't fallback and will throw this error:
0x52 = Changing the key source is not allowed while in the secure state.
01-11-2019 09:30 AM
What if the fallback is not encrypted?
01-16-2019 03:39 PM
Same concept. You cannot try to boot securely and then fallback to non-secure.
01-16-2019 10:15 PM
That also makes sense. Now what if I have 1000 units Im pushing remote updates to, with a new key written to BBRAM. If anything goes wrong in that process, I have nothing to fall back to. The whole fall-back concept is useless in this scenario unless I'm able to fall back to an image encrypted(or just authenticated) with a key in eFUSE.
My experience now from trying this with a dev board is that my 1000 units will practically brick in such a scenario. I'll have to bring in all those decices and reconfigure them by hand.
01-17-2019 08:42 AM
Suggestion:
3- Update the key
6- Issue a POR_B
01-21-2019 06:17 AM - edited 01-21-2019 07:34 AM
Yes it really does. I just didn't think of this being doable at all. How easy is it to separate the header from the boot image? A header transplant basically.
Edit: So to clarify my question, will the boot header always be as in Table 11-4 of UG1085?
01-24-2019 01:41 PM
It has been done before. You really just need to "corrupt" the synchword in the header of your BOOT.bin.
Write it up and, as last step, write the correct synch word.
01-24-2019 01:44 PM
- Will the boot header always be as in Table 11-4 of UG1085?
Yes, the format won't change.
The synch word I was refering to is at 0x24 "Image identification".
01-30-2019 12:13 AM
