in-system programming of spi rom
hello. I want to achieve the function on A7 series FPGA that"in-system programming of spi rom". I'm look forward to your help and get some datum,thank you very much!
Re: in-system programming of spi rom
I 'd strongly suggest you contact whoever designed the board,
as there are plenty of different options,
Assume you have looks at the 7 series configuration guide ?
https://www.xilinx.com/support/documentation/user_guides/ug470_7Series_Config.pdf
I'd guess you have a board to program, does it have a JTAG port on it for programming ?
Is the flash directly attached to the FPGA ?
If so I'm guessing who ever designed the board intended you to JTAG program the flash,
I
I
