is it possible to reinitializing BRAM dynamically ?
Hi Friends,
I have 4 different set if data for BRAM, while generating am able to generate with one set. after debugging with that data i want to change the data in the BRAM.
1) Is it possible to reinitialize the BRAM with other set of data using Vivado Hardware Manager.
NOTE: Any help or suggestions are highly appreciated.
Thank You
S Sampath
-Sampath
Re: is it possible to reinitializing BRAM dynamically ?
Yes you can use the updatemem tool. You would need to supply this with a MMI file.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug898-vivado-embedded-design.pdf#page=161
