is it possible to use tftp to write an image to a blank microsd card on boot?
So I have to have a blank SD card and I want to boot with TFTP and load everything onto the sd card with tftp. I'm not sure if this is possible because with a blank sd card I can't even get it to the point to let me stop the boot to do things with TFTP in the first place.
denist
Something like this ...
https://www.xilinx.com/support/answers/67157.html
denist
You can boot in JTAG boot mode, load your SW that enables TFTP (u-boot for example) and then format/program the SD card.
Then change the boot mode to SD and power cycle (or POR_B).
Would that work for you?
How would I go about doing that tho. That's exactly what I want to do I just have no idea how.
When I tftp boot into the ram it doesn't see any inserted sd card
denist
