.mcs with s25FL128S and spartan6
My board has spartan6 FPGA and flash is s25FL128S.
After creating tcp sdk file, dumping the .bitstram and .elf, working fine. But when i am creating the .mcs file using bootloader,
and dumping into the S25FL128s, It is printing the bootloader file print statements, instead of .elf.
Re: .mcs with s25FL128S and spartan6
What kind of bootloader are you using?   Do you see your bootloader hand off to your application?    AR63605 shows an example using the Xilinx SREC bootloader.
no, it is not solved my issue.
download.bit file and .elf file are not merging
How are you trying to create your boot image?
