arashr
"The core is powered down" error while downloading ZynqMP FSBL through JTAG
When I execute the following command to boot a ZCU111 from JTAG, I get the following error saying "The core is powered down" and I need to shutdown and turn-on the board again to be able to program the Image.
$ petalinux-boot --jtag --prebuilt 3
The following message shows up on UART terminal just before the error:
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1 May 25 2019 - 08:05:49
 This is the error I get:
INFO: Downloading ELF file: /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/pmufw.elf to the target.
INFO: Downloading ELF file: /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/zynqmp_fsbl.elf to the target.
    invoked from within
"::tcf::eval -progress {
            apply {{info} {
                switch -- [lindex $info 0] {
                    "info" {
                        puts -nonewline "\r[lindex $info 1]"
                    "warning" {
                        puts "\n[lindex $info 1]"
                    "data" {
                        puts -nonewline "\r[lindex $info 1] of [lindex $info 2] complete"
                    "done" {
                flush stdout
                ::xsdb::abort_check
            }}} {::tcf::cache_enter tcfchan#0 {tcf_cache_eval {download_cache_client ::tcfclient#0::arg}}}"
    (procedure "::tcf::cache_eval_with_progress" line 2)
    invoked from within
"::tcf::cache_eval_with_progress $params(chan) [list download_cache_client $argvar] {
            apply {{info} {
                    "info" ..."
    (procedure "dow" line 78)
    invoked from within
"dow "/home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/zynqmp_fsbl.elf""
    (file "/tmp/tmp.kFD6em3fSo" line 23)
INFO: The XSDB log is as follows
attempting to launch hw_server
****** Xilinx hw_server v2019.1
  **** Build date : May 11 2019 at 11:28:07
    ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
100%   32MB   1.7MB/s  00:19
Downloading Program -- /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/pmufw.elf
        section, .vectors.reset: 0xffdc0000 - 0xffdc0007
        section, .vectors.sw_exception: 0xffdc0008 - 0xffdc000f
        section, .vectors.interrupt: 0xffdc0010 - 0xffdc0017
        section, .vectors.hw_exception: 0xffdc0020 - 0xffdc0027
 section, .text: 0xffdc0050 - 0xffdd0db7
        section, .rodata: 0xffdd0db8 - 0xffdd2ecf
        section, .data: 0xffdd2ed0 - 0xffdd71c7
        section, .sdata2: 0xffdd71c8 - 0xffdd71c7
        section, .sdata: 0xffdd71c8 - 0xffdd71c7
        section, .sbss: 0xffdd71c8 - 0xffdd71c7
        section, .bss: 0xffdd71e0 - 0xffddb20b
        section, .srdata: 0xffddb20c - 0xffddbb2f
        section, .stack: 0xffddbb30 - 0xffddcb2f
        section, .xpbr_serv_ext_tbl: 0xffddf6e0 - 0xffddfadf
100%    0MB   0.2MB/s  00:00
Setting PC to Program Start Address 0xffdcffd0
Successfully downloaded /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/pmufw.elf
Failed to download /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/zynqmp_fsbl.elf
What is causing this error?
watari
Professor
Professor
Hi @arashr
Would you refer AR #69143 ?
https://www.xilinx.com/support/answers/69143.html
arashr
@watari I followed that but I still have the same issue.
DgN
Hi @arashr,
Have you ever found a woraround for this ?  I got the exact same problem even after following #69143.
N.
arashr
@DgNHi!
Yes, I restart the chip using the reset push button on the board and then I can boot the new image. It is better than recycling the whole board's power.
I disabled the CPU IDLEing and power managements in kernel but It hasn't helped. I have moved to Petalinux 2020.2 and the error is still there.
DgN
hi @arashr ,
Thank you for your answer,
I find it a shame to have to manipulate the board for it to work. This solution works for me, but my script supposed to simplify the job of developpers will sometimes fail because of this error.
FYI : The error does not come from Petalinux : It comes from XSCT. I'm opening a new thread here if you want to check it out.
N.
