"The core is powered down" error while downloading ZynqMP FSBL through JTAG
When I execute the following command to boot a ZCU111 from JTAG, I get the following error saying "The core is powered down" and I need to shutdown and turn-on the board again to be able to program the Image.
$ petalinux-boot --jtag --prebuilt 3
The following message shows up on UART terminal just before the error:
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1 May 25 2019 - 08:05:49
 This is the error I get:
INFO: Downloading ELF file: /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/pmufw.elf to the target.
INFO: Downloading ELF file: /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/zynqmp_fsbl.elf to the target.
    invoked from within
"::tcf::eval -progress {
            apply {{info} {
                switch -- [lindex $info 0] {
                    "info" {
                        puts -nonewline "\r[lindex $info 1]"
                    "warning" {
                        puts "\n[lindex $info 1]"
                    "data" {
                        puts -nonewline "\r[lindex $info 1] of [lindex $info 2] complete"
                    "done" {
                flush stdout
                ::xsdb::abort_check
            }}} {::tcf::cache_enter tcfchan#0 {tcf_cache_eval {download_cache_client ::tcfclient#0::arg}}}"
    (procedure "::tcf::cache_eval_with_progress" line 2)
    invoked from within
"::tcf::cache_eval_with_progress $params(chan) [list download_cache_client $argvar] {
            apply {{info} {
                    "info" ..."
    (procedure "dow" line 78)
    invoked from within
"dow "/home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/zynqmp_fsbl.elf""
    (file "/tmp/tmp.kFD6em3fSo" line 23)
INFO: The XSDB log is as follows
attempting to launch hw_server
****** Xilinx hw_server v2019.1
  **** Build date : May 11 2019 at 11:28:07
    ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
100%   32MB   1.7MB/s  00:19
Downloading Program -- /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/pmufw.elf
        section, .vectors.reset: 0xffdc0000 - 0xffdc0007
        section, .vectors.sw_exception: 0xffdc0008 - 0xffdc000f
        section, .vectors.interrupt: 0xffdc0010 - 0xffdc0017
        section, .vectors.hw_exception: 0xffdc0020 - 0xffdc0027
 section, .text: 0xffdc0050 - 0xffdd0db7
        section, .rodata: 0xffdd0db8 - 0xffdd2ecf
        section, .data: 0xffdd2ed0 - 0xffdd71c7
        section, .sdata2: 0xffdd71c8 - 0xffdd71c7
        section, .sdata: 0xffdd71c8 - 0xffdd71c7
        section, .sbss: 0xffdd71c8 - 0xffdd71c7
        section, .bss: 0xffdd71e0 - 0xffddb20b
        section, .srdata: 0xffddb20c - 0xffddbb2f
        section, .stack: 0xffddbb30 - 0xffddcb2f
        section, .xpbr_serv_ext_tbl: 0xffddf6e0 - 0xffddfadf
100%    0MB   0.2MB/s  00:00
Setting PC to Program Start Address 0xffdcffd0
Successfully downloaded /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/pmufw.elf
Failed to download /home/arash/Projects/ZCU111/built_linux/xilinx-zcu111-2019.1/pre-built/linux/images/zynqmp_fsbl.elf
What is causing this error?
Mentor watari
Mentor
Re: "The core is powered down" error while downloading ZynqMP FSBL through JTAG
Hi @arashr
Would you refer AR #69143 ?
https://www.xilinx.com/support/answers/69143.html
Best regards,
@watari I followed that but I still have the same issue.
