Observer encrypt1977
u-boot build failed
Dear Sir,
      When I tried building uboot, I got the errors as the belowing:
*** Your GCC is older than 6.0 and is not supported
arch/arm/config.mk:69: recipe for target 'checkgcc6' failed
make: *** [checkgcc6] Error 1
      I installed codesourcery for xilinx from  https://github.com/xupsh/CodeSourcery.git.
and the version is : gcc version 4.7.2 (Sourcery CodeBench Lite 2012.09-104)
     My ubuntu installed gcc 6.4 as the belowing message:
gcc version 6.4.0 20180424 (Ubuntu 6.4.0-17ubuntu1~16.04)
     Should I unstall codesourcery or how to change to use gcc 6.4 to compile Uboot?
Scholar watari
Re: u-boot build failed
Hi @encrypt1977
I see.
I know this solution.
Your problem is prefix issue and path issue.
Your solution depends on version of petalinux.
So, if you are facing like this issue, I suggest to make sure directory name in <patalinux install dir>/linux-i386/(gcc compiler name).
Best regards,
Scholar watari
Hi @encrypt1977
It's path issue.
Would you change path setting to add the path to GCC6.4 ?
Best regards,
Hi Watari,
    Thanks for your reply. If I comment out the path to codesourcery in .bashrc, it will report command not found.
but if i  use : export CROSS_COMPILE=arm-linux-gnueabihf- , it will compile successfully.
Scholar watari
Hi @encrypt1977
I see.
Best regards,
