zcu102 rev 1.1 stuck in stage 3 partition no: 1 at XPFW: Calling ROM Isolation Handler..Done
zcu102 rev 1.1 board stucks at  XPFW: Calling ROM Isolation Handler..Done in stage 3 partition no:1
But i'm able to boot the same on zcu102 rev 1.0. Here are the logs
Xilinx Zynq MP First Stage Boot Loader
Release 2016.3 Mar 16 2017 - 17:03:30
Platform: Silicon (3.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU9EG
Processor Initialization Done
================= In Stage 2 ============
SD1 with level shifter Boot Mode
SD: rc= 0
File name is BOOT.BIN
Multiboot Reg : 0x0
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x5
Partition Header Address: 0x280
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x3BEBBC
Data word offset: 0x3BEBBC
Total Data word length: 0x3BEBBC
Destination Load Address: 0xFFFFFFFF
Execution Address: 0x0
Data word offset: 0xF5B0
Partition Attributes: 0x20
Destination Device is PL, changing LoadAddress
Bitstream download to start now
XPFW: Calling ROM PWRUP Handler..Done
Re: zcu102 rev 1.1 stuck in stage 3 partition no: 1 at XPFW: Calling ROM Isolation Handler..Done
If this is a new ZCU102, there was a DDR change, try with 2018.3, AR71961
