About digital down converter ip-core in virtex-5
I want to use the digital down converter ip-core in virtex-5, but I find the digital down converter ip-core can not support the series of virtex-5, I want to know how can I use the digital down converter ip-core in virtex-5, thanks for your reply!
Refer to the AR below to work around the problem by generating the core with Virtex-4 firstly :
thank you very much! I will try.
It's important to note that IP generated for a different architecture may be able to implement but it will not be optimized for Virtex-5 which has some significant changes in the architecture.  Most notably 6 input LUTs and the DSP48E.
