About the co-simulation issue in system generator
Dear Everyone,
  Now I am trying to co-simulate my FPGA design in form of BLACK BOX in system generator(the module is write in verilog), the model output of FPGA Black BOX is connected to drive  a H-Bridge electrical circuit ( a switch-mode power amplifier), my problem is that the FPGA clock period is 10ns and the Simulink system period is 1 sec(that is the normalized period), but the electrical circuit connect with it works in a real time, that means it could not work in such normalized time, could anyone give any idea to deal with this?
thanks a lot!
回复: About the co-simulation issue in system generator
can you clarify your question? You can set Simulink system period to any value.
Thank you, Moderator, it has been solved, i set the simulink system period in the Xilinx Token to 10ns(ie, 1e-8) to make it equal to the FPGA period clock, and then it works, the time in simulink now equals to physical time,  so the electrical circuit could then co-works.
