BPSK Implementation on Zynq SDR
                     I am trying to implement BPSK digital communication on Zynq SDR. First I implemented it on the Simulink block without Zynq SDR. I got the expected waveform. After I added the hardware block in Matlab, I am getting the output. but the input message and output message are mismatched.  This is not happening in the simulation.  I configured the hardware SDR parameter as per the input message.
                    I have used Bernoulli binary generator to generate input messages.
   BPSK Simulink block
   BPSK Simulation waveform
   SDR Block Configuration
   Transmitter
Receiver
   Bernoulli Binary Generator
What was the problem with this configuration?
Thanks & Regards
Paul Kannan G
Re: BPSK Implementation on Zynq SDR
Hi @paul_kannan
It looks you are using the Matlab's block (not the Xilinx SysGen blocks).
May be you can check on the Matlab Forum page.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
