diverger
'Best Precision Fraction Length' function in FIR Compiler when coefficients are all integers
When all coefficients are all integers, how the 'Best Precision Fractional Length' work? Will the integer coefficients be converted back to fractional numbers and be processed further internally?
nathanx
@diverger The "Best Precision Fractional Length" is to automatically determine the coef fractional length for the best precision, so, if all the coefs are integers, then the "Best Precision Fractional Length" will not be available to use.
