Binary Counter v12.0 verilog file
Hi!
I am trying to use DSP48E2 block to implement a 8 bit counter.
I came across Binary Counter V12.0 in the IP library. But it looks like the RTL and simulation is only available in VHDL.
I was wondering if this IP is available in verilog. I am more concerned with simulation aspect as I don't have mixed language simulator.
-AK
Hi @ami.kum
The IP is only available in VHDL. Which simulator are you using ? If you have the Vivado simulator,it is a Mixed language simulator and it should work on it.
I am using ModelSim. I will switch to Vivado Simulator.
@ami.kum,
It is also possible to do mixed language simu using ModelSim. I suspect you have some Modelsim setting incorrect.
FPGA enthusiast!
All PMs will be ignored
Yes. It requires a mixed language simulation license. I only have license version which support only Verilog.
