ahmed_alfadhel
Bit Error Rate calculation
We know that if we want to caculate Bit Error Rate (BER) for a transmitter and  a receiver in Matlab Simulink model, "Error Rate Calculation" block will be used for this task. (Kindly, see the attached picture).
Then I used Vivado IDE to design a transmitter model and receiver model . In case I implemented my design on two seperate FPGA boards how to calculate BER ?
meherp
I assume that you are doing the prototyping only.
One of the way is to locally generate the transmitted signal at the recevier end.
Syncronize the locally-generated-tx-signal with dectect signal; and save it in a file.
Finally, use matlab to find the BER.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
