brent.aandd
Cannot add multiple speed grade parts to compilation target
I want to add multiple parts for selection in a custom compilation target. This seems to be possible only when I am selecting a completely different device. If I add multiple speed grades or packages of the same device, it fails with "Reference to non-existent field 'temps'." in the matlab window when I try to select the Part in the token gui.
Example:
The following works when the device is different (placed in setup_sysgen_token callback
add_part( obj,'kintex7','xc7k70t','-1','fbv676','');
add_part( obj,'kintex7','xc7k160t','-1','fbg484','');
However, if you add a different speed grade of the same device, it fails:
add_part( obj,'kintex7','xc7k160t','-2','fbg484','');
Any thoughts? Can I get around this by creating multiple targets? It doesn't appear that this is possible within the same class.
Thanks!
vkanchan
Does the api throw any error when speed grade of same device are added ? Can you share a example design/script that can help us reproduce this and check ?
ravidapu
The best way to set device in the sysgen tokes as below
blockList = find_system('bramtest', 'LookUnderMasks', 'all', ...
'Type', 'block', 'Tag', 'genX')
sysgenBlock = blockList{1};
sg_hdle = get_param(sysgenBlock, 'Handle');
current_sys = get_param(sysgenBlock, 'Parent');
xlSysgenGUI('startup', current_sys, sg_hdle);
fighdl = xlfindsysgenfig(sysgenBlock);
xlpartchoicechosen('kintex7','xc7k160t', '-1', 'fbg484', fighdl);
I hope it helps
Raju A.
