Cannot find FFT V9.0 C bit accurate model in Vivado 2017.2
I cannot find the C - model of the FFT IP in the Vivado 2017.2.  C-model is not seen in the folder .srcs/sources_1/bd/ip/x_fft_0_0 . And also it is not seen in the IP Sources tab in the Sources window of Vivado 2017.2.  C-model would be one of the these two places in the previous version of the Vivado.
Best Regards,
Tags (3)
Re: Cannot find FFT V9.0 C bit accurate model in Vivado 2017.2
You can get the C model from the Xilinx install area.  For example:
...\Vivado\2017.2\data\ip\xilinx\xfft_v9_0\cmodel
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
