Change 5x5 filter coefficients
Hi ! The Xilinx System Generator Reference Guide says that " You cansubstitute your own coefficients and scale factor by  modifying the mask of the 5x5 filter block, under the Initialization tab" . When I open this tab, its "read only". How can I change the matrix coefficients for lets say edge filter ? I am using System Edition 13.3 with R2011a version of MATLAB (64 bit).
Re: Change 5x5 filter coefficients
It may be because you need to save a copy of the model to a differnt directory.
You should be able to modify the design, once you have a copy in you own project directory.
Chris
Video Design Hub | Embedded SW Support
@ Chris - I have checked this with just pasting a  5x5 filter block from simulink library into a blank file. Its still read only !
Teacher rcingham
Have you tried changing the file attributes/permissions via the OS?
"If it don't work in simulation, it won't work on the board."
@rcingham - It is not possible to edit checkboxes and drop-down boxes in the Mask Editor (as its in read only mode). Did you meant this ?
Teacher rcingham
"Did you meant this?"
No.
I meant changing the file attributes using Windows File Manager, or using a 'chown' command in Linux/Unix.
Rather thank copying and pasting, you should completly move the file to a new location.
If you copy and paste, it might be linking the blocks back to the previous model.  I've seen that happen in Simulink before.
Chris
@Chris - I don't think you got my point. You can select a new block from the Simlunk library, put that in a new(/blank) file and try to edit that. It won't happen.
@rcingham - Its not a file attribute. Its a block attribute. If you select this block from the simulink library , put in a new(/blank) file , right click on the block and select view mask, the mask editor that opens is read only.
