Ibra
Choice
To implement an IP CPRI, IP PC-CFR..etc .... Which platform should I use? Linux or Windows? Vivado or simulink (Matlab)?
Explain my please why linux? or why Windows?
Why Vivado? or why Simulink?
Thank you in advance.
meherp
Window and Linux both are fine for these IPs.
If you planning to create the Linux or Baremetal, then you need Petalinux-installation (along with Vivado) which will work on Linux machine only.
Simulink you can't use, as we do not have Matlab model (more specifically SysGen Model) for these IPs.
In any case, Vivado is mandatory.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
