Codic 5.0 in System Generator dosen't have output
I want to test the function of Translate complex num to real and phase with Cordic 5.0.
But whatever I change the input type or parameters in Cordic 5.0, it just display the 0.
I want to know where I need to change.
Thanks!
Re: Codic 5.0 in System Generator dosen't have output
what is your tool versions. You may not simulating for enough time . Can you try putting inf in simulation time. You can generate netlist and simulate in Vivado
I would also recommend you to use latest version of vivaodo and cordic.
when i simulated for 100 simulation time its working fine
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
