akshay_iyngr95
Coefficient file for fir compiler
I have generated coefficient file for a filter in FDATool in MATLAB which gives me the coefficient file with extension .fcf .
I have to use this coefficient file in FIR compiler in Vivado HLS which is expecting file of extension .coe .
How can I get .coe file from FDA tool in MATLAb or how can i convert .fcf to .coe
Thanks and regards,
Akshay M
bruce_karaffa
An fcf file looks like this:
% Generated by MATLAB(R) 9.2 and the Signal Processing Toolbox 7.4.
% Generated on: 09-Mar-2018 09:20:21
% Coefficient Format: Decimal
% Discrete-Time FIR Filter (real)
% Filter Structure  : Direct-Form FIR
% Filter Length     : 45
% Stable            : Yes
% Linear Phase      : Yes (Type 1)
Numerator:
 0.000097547980806971738
 0.00031118118575867499
 0.00070657071413631443
 0.0012740818962985352
 0.0019029775546380559
The coe file looks like this:
RADIX = 10;
COEFDATA =   0.000097547980806971738,
 0.00031118118575867499,
 0.00070657071413631443,
 0.0012740818962985352,
 0.0019029775546380559,
 0.000097547980806971738;
All you need to do is replace the Matlab header with
RADIX = 10;
COEFDATA =
then put a comma at the end of every coefficient except the past one.  Put a semicolon at the end of that one.  I wouldn't be surprised of somebody out there doesn't have a script to do this.
bruce_karaffa
% Stable            : Yes
Numerator:
RADIX = 10;
RADIX = 10;
COEFDATA =
