funk
Compilation status --> Running netlister... (forever)
I use Matlab R2008a and Xilinx ISE 10.1 (with SP3).  And I try to compile a simple Simulink
model consists of Xilinx blocks to HDL netlist.
Sometimes the compilation of my model completes without a problem, but sometimes the compilation
never ends and the compilation status remains forever to "running netlister" mode  and I terminate the
compilation process by the task manager closing Matlab.
And my question now: How could I fix this problem? :)
Thanks a lot!
nathanx
Did this issue occur with the same model? Did you install IP Update of ISE 10.1, DSPtools 10.1.03?
frs4
I have the same problem with system generator 12.1...
