Convolutional Encoder
Hi ,
How can ı get convolutional encoder ip core's evaluate ip licence?
Is there any? Can you write a link to me?
Re: Convolutional Encoder
Hello @selcukbalsuzen,
In PG026 PAGE-05 it is mentioned that "This Xilinx® LogiCORE™ IP module is provided at no additional cost with the Xilinx
Vivado® Design Suite under the terms of the Xilinx End User License." You can refer to the below link for more information:
https://www.xilinx.com/products/intellectual-property/convolutional_encoder.html#overview
Naveen
Naveen
Thank you.
Regards.
