Newbie noamchomsky
Crazy CIC Decimator Output
I am using CIC decimator from system generator. First, I developed a model in a separate file and tested it for different input data. Then i moved this model to a different file and a bigger model of complete transmitter and receiver, with almost the same input, the output of CIC decimator is not good. Instead of decimating and producing the same output as input (with of course less no. of samples), it is giving an output with very large negative values only. Please guide how can i correct this. The output of first case and second case are attached. The configuration of CIC decimator is as follows.
Stages: 5
Group Delay: 1
Decimator Ratio: 25
Input Q Format: 14.13
Output Q Format: 34.9
The snapshots' description is as follows.
case1.jpg: good one
case2.jpg: ugly one
What possibly can be the problem. Please guide.
Best Regards,
Tags (2)
Newbie cdramuneer
Re: Crazy CIC Decimator Output
You should use FFT Spectrum scope to better visualise decimation of ur input if it comes right over there then you are done decimation is not always clear in Time domain(in scope)
Best of Luck
