Observer rforsyth
DDS Output rate too slow and staircased
Hello -
I have had this problem using both the FIR core gen and the DDS core gen where I am getting a staircased 6 microsecond output regardless of system clock frquency or output frequency settings.
The simpler case is the DDS, I have tested in a realtime system using a logic analyser and have tried system clock of both 20 Mhz and 120 Mhz, with output frequency setting of 1 Mhz , 20 Mhz and 60 Mhz with the output rate always fixed at approx 6 uSec per sample.
How can I get better resolution on the phase of the output? I see no reason that I shouldn't be able to get 16 nanosecond phase increments with a 120 MHz system clock.
Observer rforsyth
Re: DDS Output rate too slow and staircased
Here are the GUI inputs
Observer rforsyth
To be clear, you are changing both the core's system clock parameter AND the rate of the actual clock signal connected to the core?
Is this simulation? Can you post a pair of .xco files that you expect to be different and aren't?
www.xilinx.com
Observer rforsyth
Yes I am changing both the input clock (wired to input of core) and the parameter in the GUI
This is not a simulation - it is the actual logic analyser capture on an output test connector of the system under development, and yes the sampling rate is sufficient, I have sampled at 20 Mhz and at a finer resolution of 500Mhz.
Observer rforsyth
It isnt a matter of expecting the .xco's to be different, I just want one that works!
I would double check the input clock frequency to the DDS core running in HW. Bring it out to a pin and look at it on a scope.
Cheers,
Jim
Observer rforsyth
Ok I tried a higher input clock as suggested - bumped it up to 180MHz and got a reasonable smooth output.
Then i gradually worked back down  - 160, 140 still looked good, then back to the original 120 and it looks good. So I really have no idea what fixed it or what was wrong.
Thanks for the input, resolved for now. If it reoccurs I will repost.
