Observer kbkien
DDS generates quarter/half wave?
Hi all,
I used coregen to generate a dds as below parameters:
f_clk = 150 MHz
f_output = 150 MHz
B_n = 16 bits
I am interested on the sine/consine waveform and I have performed a simulation on modelsim. What I noticed was the sine wave generated by dds is always positive values which isn't a a full sine wave.
Is the dds only generated half/quarter of the sine wave? If so, I guess I need extra logics to get it work in a full cycle.
Re: DDS generates quarter/half wave?
Are you interpreting the output data as 2's complement?
www.xilinx.com
www.xilinx.com
Observer kbkien
Yes. I've solved it by reducing the number of bits (phase) from 16 to 10. And it works. Don't exactly understand what happened.
