DDS output format and Complex multiplier
I have to multiply a signal coming fro a DDS output with an other signal.
I see that the DDS output format is fix16_15 and the Complex Multiplier core input (channel B)  is fix16_0.
What fix16_15 and fix 16_0 mean ? Do I have to translate fix16_15 to fix16_0 to be compliant with the  Complex Multiplier input ?
Thank you.
@cvasselin
You can find the answer in below post. Please avoid duplication of the posts.
https://forums.xilinx.com/t5/DSP-IP-and-Tools/DDS-output-format-and-interface/m-p/925209
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
