tranphan1980
DPD_SMP error when start
HI  Support Team,
Currently, we are porting DPD in to our DFE design. In this design:
- we choose SMP mode for DPD.
- s_axi_ctrl_aclk and s_axi_user_aclk are connected to clock 200 Mhz.
- s_axi_ctrl_2x_aclk is connected to clock 400 Mhz.
- clock 200 Mhz and clock 400 Mhz are generated from clock FCLK_CLK0 (200 Mhz).
But, we have issue when start DPD:
--- Xilinx Digital Pre-Distortion v8.0
--- Build: Linux SMP: CL1734100
--- Opened DUnhandled fault: external abort on non-linefetch (0x818) at 0xb491904c
PD Device at /dev/uio0
--- Initialising DPD Software
--- DPD Tpgd = e6f38000
[b491904c] *pgd=36e45831imer Thread Created
--- Resetting DPD Timer
--- Initialised In, *pte=81c00743, *ppte=81c00c33terrupts
--- DPD Timer Thread Running
Bus error
Our device tree, you can see at the attachment.
Please tell us if you have any hint,
Best regards,
nathanx
DPD v8.0 is only compatible with Vivado 2016.3, have you referred to DFE demo with DPD v8.0?
