misha2020
DSP Macro 3.0 accuracy issue?
Hi to all.
I am comparing DSP Macro 3.0 with instruction A*B+P vs. the sequence : multiplier + accumulator. The results are similar but DSP  slice output has significant error. (The sequence mult +_accum is checked against Matlab and gives perfect output).
Possibly I used DSP Macro 3.0 incorrect. Please have a look
Michael
My SYSGEN-Simulink  model is attached. Matlab version 2019b and SYSGEN 2020.1.
nathanx
Did you set P output to full precision? If you do not, please try it and check if you can expected results.
misha2020
Yes, I did
nathanx
can you upload the model or provide DSP48 Macro settings?
