ramonal
DSP system gerator; specify IOB Pad locations
I am working with the Virtex 4 FX development board with an additional P160 analogue board. For creating a control system I want to read the data via the analogue board. Problem: When I specify the Virtex 4 specific pad locations as a cell array for the gateway in and the gateway out block I got following error message when I  launch the system generator block:
Errors occurred during netlist generation.
Error in 'AD_converter1/ADC1OEn': Parameter '{AC22}' cannot be evaluated.  MATLAB error message: Error using ==> sim
Undefined function or variable 'AC22'
I appreciate any help with this problem.
Ramona
ywu
Which version of SysGen? What value did you put in for the IOB location box? I just tried it in SysGen 11.4 as shown in the attached snapshot and it is working fine.
Cheers,
Jim
