DSP48A block and 3SD3400A
I have problem with DSP48A block instantiation. I used instantiation form Language Templetes but ISE compiler shows message below Xst:2677 - Node of sequential type is unconnected in block . MUX_I is a single file (it's not a part of hierarchical design).It seems ISE couldn't find these DSP block. Could anyone help me? Best regards
There may be a port mismatch, as I think there were some errors in the language templates prior to 9.2.04i.
You might want to look at the AR below, or if this doesn't resolve the problem, then open a case with the Xilinx Technical Support, and submit you files so that they can troubleshoot the issue.
http://www.xilinx.com/support/answers/25096.htm
Chris
Versal ACAP: AI Engines | Embedded SW Support
