araneidae
DSP48E1: is OPMODE=0111000 and CARRYINSEL=001 a valid combination??
During simulation (using QuestaSim) I see the following messages generated:
# ** Warning: OPMODE Input Warning : The OPMODE 0111000 with CARRYINSEL  001 to DSP48E1 instance is invalid.
Is this really an invalid configuration for the DSP48E1, or is there a fault in my simulation library.
According to UG479, this combination has the following significance:
  • OPMODE=011xxxx => Select Z = C
  • OPMODE=xxx10xx => Select Y = -1
  • OPMODE=xxxxx00 => Select X = 0
  • CARRYINSEL=001 => CIN = ~PCIN[47]
I cannot find where in the simulation this message is generated, I've looked at both data/vhdl/src/unifast/primitive/DSP48E1.vhd and data/vhdl/src/unifast/primitive/DSP48E1.vhd, and I can't see anything in UG479 precluding this combination.
xilinxacct
Instructor
Instructor
@araneidae
Many other people are also seeing this... follow this thread... https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/Warning-OPMODE-Input-Warning-The-OPMODE-0110X0X-with-CARRYINSEL/m-p/939048
It is not answered definatively, but the previous concensus was it could be ignored.
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed.
araneidae
So let me maybe put this another way.  This is a bug in the simulation library which Xilinx are aware of but have no intention of acknowledging or fixing?
Guessing based on the forums is not a great way forward.
xilinxacct
Instructor
Instructor
@araneidae
FYI, I got the definative work back from Xilinx to on this...
You can change the "cosim_design" in script.tcl to "cosim_design -disable_depchk" to skip this check.
Yes, these can be safely ignored.
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
